Re: Power pack
test CDI output voltage with a peak reading meter or a DVA attachment on a digital meter.
YOU cannot use RMS or ac voltage, must be peak.
test each coil primary for correct output at the problem speed.
check plug cap resistance for correct resistance.
test pulser coil resistance,shorts to ground and proper output voltage at the problem RPM.
test stator high and low speed coils for resistance,shorts to ground and proper output voltage at the problem RPM. all voltage tests must be done with the correct peak reading meter.
test the crank position sensor resistance check the air gap its fixed but should be .020 or so from the flywheel.
check,very carefully, throttle position sensor output voltages,can use a standard meter preferably analog so you can catch any worn spots while moving the throttle.
