1978 40hp Mercury. Hard to start,sometimes starts and runs fine till you shut it off for 15 or 20 minutes.Have to crank and choke engine several times before restarts and them sometimes its only running on one cylinder then the other cyl. starts firing after a minute or two.(maybe)and runs good again.Confidence starts building then all of a sudden it dies out and quits.Then same procedure as before.It will fast idle enough to get back to boat dock as long as you don't try to give it any more throttle. Checked fuelhoses,clean fuel ,replaced inline fuel filter,and pickup tube seems to be ok in tank.How do i check the fuel pump operation and what are the specs for this engine. Seems like fuel problem.Am i on the right track?<br /> Thanks vtp54
