Re: power steering adjustment?
I checked power steering fluid level and it was low so I added some. I hoped that this was the issue. I took the boat out and it seemed to be better but then got worse again. It got too dark and I wasn't able to check the level again after taking it out. It is possible this issue is due to low power steering fluid.
It seems that the dead spot happens no matter where the steering wheel is at. It seems like you have to turn it a lot for the motor to actually turn, which I think is what leads to the overcorrection the other way. Not sure if this makes any sense. I will check the level again in the power steering reservoir.
In any case, to answer your question, its a Mercruiser 4.3 engine with alpha one drive.
Thoughts? Anything else I can check/adjust besides power steering fluid?
Thanks....
Nope,.... Low oil won't cause that,...
Did you read my last post,..??
You need some help to hold the drive, while the steerin' wheel is shaken, then the wheel held, while the drive is shaken, While You observe the various linkage connections for Slop,...
