Power steering fluid loss
427allen
I have a 1987 Bayliner Trophy with a 5.7 OMC (Chevy) I am losing power steering fluid, I can't locate the source of the leak is it possible for the cooler to be leaking and pumping the fluid overboard?
Reinell-BRXL-191
Re: Power steering fluid loss
If you have a power steering fluid loss, and cannot see anything in the bilge, then it is leaking inside the cooler...
Idlespeedonly
Usually (not always) when a cooler has a leak, It will leak water into the oil. Since the water pressure is greater than the oil that is flowing through the cooler.
Ayuh,... Welcome Aboard,.... Ya, that happens when it freezes with water in it,....
It's supposed to be drained in winterization,...
427allen
Thanks for the responses I will have the cooler checked
