nola mike
- Apr 22, 2009
- 5,695
I've hooked up the power steering running the engine in the driveway. yesterday, I could get the ram to retract, and then it would extend on its own. I found the procedure to balance it, and have it so that the ram now stays in a neutral position. However, regardless of which way I hold the actuator, the ram retracts, which I don't think is what is supposed to happen. If the actuator is in the neutral position, I can extend the ram with my hand. See the video below. A little bit tough to shoot one-handed. Also, as you can see, the actuator takes quite a bit of fiddling before the ram moves. Any ideas?
https://youtu.be/5IalmLGusUk
