Power Steering Oil - Dextron?
baker556
Hi all,
Is there a preferred power steering pump oil to be used, should ATF fluid Dextron 2 or 3 matter?
Thanks
Hi all,
Thanks
your manual either calls out ATF or SAE 30 for a VP
if its red, its ATF, if its light amber color, its SAE 30
do not mix Dexron with ATF, dont mix Type F with ATF, dont mix Dexron and Type F
ATF is usually associated with MOPAR or other. GM vehicles use Dextron, Ford vehicles use Type F
baker556
Volvo is suggesting Duraplus power steering fluid - believe this Dextron ATF DEXIII is acceptable.
