89 Holiday Mansion Baracuda (house boat)
Single AQ271C duo-prop w/ power steering
Problem: Power steering assist has been marginal if any. Servo pump was squealing when wheel turned even slightly. Fluid (dextron) smelled burnt. Turning steering wheel can drop rpms significantly at idle.
Action: Changed PS pump and purged fluid - changed to 10/30 motor oil as per sticker on old pump. While engine was off, was able to get fluid to flow from pump reservoir thru the system and out the return line simply by turning the steering port to starboard and back. Hence no obstruction and (likely) no air.
Result: Still squeals - no improvement.
Suspicion: need replacement power steering cylinder
Question: The volvo parts listings show a repair kit that is no longer available - Anybody know where a kit might be found or someone that might rebuild the cylinders? The part number might be 7743470 062 r45
