Power Steering Pumps squeals
jfl1959
Hello
1979 amf crestliner 2455 mercruiser i/o 228 (jasper rebulilt in 1995 I think)
Okay so i am starting to hear my power steering pump squeal. its gets a little louder when I turn the wheel. When I am trolling it is squeaky. The pump was almost dry before I filled it to normal. It is not hard to steer or turn the wheel. But of course the noise is probably not a good thing. right?
Is it usually the pulley or the pump? does one get replaced without the other?
Once it starts to squeal how fast will it fall apart. I have no interest in loosing steering away from the dock.
Any help would be appreciated
Thanks
Jim
Don S
Re: Power Steering Pumps squeals
Sure it's not a loose belt............. usually because the pulley is all rusty?
Ayuh,......
It sounds like you've got several Issues going on...........
Bad Belts,......... And a Bad Leak................:rolleyes:
