Power tilt and trim motor
bigge31566
I am trying to change power tilt motor on a 1997 150 hp and cannot find connection to disconnect the 2 wires going to motor supposely in the braided tube any ideas where it could be
Will Bark
Re: Power tilt and trim motor
There should be a connector located just below the black box that houses the relays for the trim motor; the black box is under the cowl attached to the block of the engine, Good luck.
bigge31566
I seen that but I was not sure that the connector would make it through the bottom of engine and the braided tube
boobie
You may have to remove the inner terminal connectors ( metal part ) from the plastic part of it.
