Power tilt and trim
Status
Not open for further replies.
DMcGraw
The up switch on my power tilt and trim will not operate. I have a 200hp Cobra Sterndrive. The down button works fine but the switch is difficult to get to short of taking the entire control arm off. Any suggestions?
karayj
Re: Power tilt and trim
How many relays do you have if ou have 2 swap it around take the 2 small wire fom each relay and switch them and see if it now goes down this will tell you if its the relay or the switch on the throtle control......
Status
