Re: power tilt problem on 1997 , Force 75 HP
Try lifting the prop by hand. If you can lift engine by hand but then it sinks right back down then getting the fluid pump rebuilt/replaced is your starting point. If the trim motor spins but you can't budge the outboard then check internal hex shaft between trim reservoir and base. If no trim motor spinning then check electrical switches, power, relays, and circuit breakers. If you get good power but no motor spin then motor is needs rebuilt/replace.
