power tilt problem
dshank
we have a 98 force, it will power tilt down not up, it makes no noise when tring if we switch the cables we can get it up. could it be the switch in the handle? is it hard to fix?
superman
Re: power tilt problem
Hi dshank: If the motor is only running in one direction you have either a bad switch, solenoid or the wires connecting it in that mode. If you have a voltmeter it can be easily diagnosed. if not changing the switch would be the logical choice. Good Luck
