Power tilt & trim help needed !!!!
RAEGIN94
I have a 94 Suzuki 75 HP without a power tilt & trim and I have found a power tilt & trim that has DT75 stamped on the metal tag, will it fit my motor?
Also, my motor is a 75 hp, but the clamp that's on the transom that the motor sits on has a metal tag stamped with DT65 and this is what's throwing me off, would the clamp from a 65 hp hold a 75 hp?
Thank you.
99yam40
Re: Power tilt & trim help needed !!!!
Sounds like someone has been swapping parts between motors. Maybe someone just put 75 cowling on a 65.
You will have to look to see what power head and other parts you have to find out what motor you have.
Can you go back and ask who sold it to you?
Did you get a title for the motor when you bought it?
RAEGIN94
Yeah, I thought maybe the previous owner did some swapping around.
But do you think the Suzuki DT75 power trim unit would work for me even if the motor I have is a Suzuki DT65?
99yam40
look at the part breakdowns of the two motors and compare part #s
