Power tilt/trim Reverse & Stumps question
tbarr106
hi <br />i have a 1976 115hp merc inline 6 <br /><br />im adding a power tilt/trim system <br /><br />what my is question how does the Hydraulic<br />pump and rams react when you hit a stump ?....<br /><br />and how do they react in reverse ?....<br /><br />im new to power trim and dont want to scew up my Transom or lower unit !.....<br /><br />my pump has a reverse lock knob what and how does it function ? (trailering i believe )....<br /><br />any advice and expertize or links is welcome<br /><br />im installing the trim unit wiring and refurbishing my deck boat myself <br />so as you can see im very mechanically inclined.....<br /><br />so please feel free to get into detail about system ......<br /><br />which is the merc 4 port round mtr pump<br />single Solenoid type (Why did they add a second )<br />2 rams and 3 button trim switch Up /down/up-out<br /><br /><br />thanks
achris
More fish than mountain goat
Re: Power tilt/trim Reverse & Stumps question
watermark.php
<br /><br />Hope this helps.<br /><br />Chris.............
tbarr106
ok great this a great diagram <br />i see item J is a impact relief valve <br /><br />how does this function when you hit a stump <br /><br />1100 psi to 150 psi check ball ? impact relief valve has a 150 psi ratio before it kicks in ?<br /><br />and lets hyd fluid bypass or backflow to resovoir <br />the slide valve must be a big part of it<br /><br />how does this apply to the reverse situation <br />instead of hitting a stump...?<br /><br />basicly what happens when you hit a stump...?<br /> <br />a vavle must go wow we just hit something<br />(i.e impact relief valve seems like the logical way to let the lower unit swing up and not rip your transom out<br />im i figurining it out or am i in the twilight zone<br /><br />thanks
Chris1956
tbarr, I have the same T/T system as was original for your motor. When you hit anything going forward, the motor will tilt up, hopefully without damage. I hit a telephone pole at 45MPH without damage. I hit a rock at 35 MPH, and it only broke off the skeg, which I thought was a bargain.<br /><br />The reverse lock knob when released, will allow you to tilt the motor by hand. I only used it during the winter, when the battery was disconnected and I wanted to tilt the motor up.<br /><br />If you hit something while in reverse, the T/T system is not going to give easily, since it has to be firm enough to maintain trim at full throttle in forward. I am always extra careful while in reverse.
wilde1j
You have zero protection in reverse. Your only help is DON'T HIT ANYTHING, bc if you do at any speed, something's going to break.<br /><br />In forward, the motor will kick up during a hard (or soft) hit when at planing speeds.
tbarr106
hi <br />thanks for the info guys<br />my rams came in this week and im bidding on several pumps on ebay<br /><br />i see a lot of 2 port mercuiser pumps<br /><br />and some 4 port outboard pumps for my model<br />some with reverse lock some without<br /><br />im wondering if these pumps are rated for different hp mtrs ?do they have different PSI ratings for the smaller mtrs vs larger mtrs<br /><br />im buying a pump used ... has anyone rebuilt one?<br />was it a hassel or fairly simple ?<br /><br />ive rebuilt different type's of pumps with relative ease before<br />relace orings/ snap rings/seals/impellers /ball-check/ect.. clean and assemble ...<br /><br />ive been reading this forum on most common trim problems<br />seems the check balls and orings solenoids & elect mtr..are main culprits for pump failure<br /><br />or seals in rams..too<br /><br />are rebuild kits avail for valve body?<br /><br />seems a elect starter repair shop could rebuild the mtr/ brushes ect.. <br /><br />also.. im looking at a diag of the trim cly assembly and notice item 44 is a strap of some sort called a tilt stop part# a-63443<br />with a tube and pin also<br />i take it this is a restraining strap to limit tilt travel when trailering?<br /><br />one last ? i see lots of ad's for transom savers are they a piece that fits between the rams to stop mtr from bouncing and relieve pressure off rams ?<br /><br />any other tips on installing rams and pumps wiring is apreacited<br /><br />thanks <br />tbarr
