I have a '99 Yamaha F50TLRX. When I first took it out of storage this spring I trimmed the motor all the way up to move it, but it would not trim down. It would only click under the cowling. I used the manual release to lower it and did it again with the same results. I talked with a friend and was told to try tapping on trim motor housing with a hammer to free it up. This worked initially although it was sluggish. It will now get stuck at least once or twice each time I take the boat out going up or down. It will work again with some tapping. Could this be a fluid issue or is it just going bad. I tried to take the big flathead screw out to check the fluid and it wouldn't budge, almost messed up the screw. I feel like I may break something if I go any further with that. Just wondering if I should keep going down that road.
Thanks,
HH
Thanks,
HH
