power tilt up button not working
bigge31566
I have a 1999 90hp Johnson and the pump and motor work good on t&t but the up button on the shifter dont work , the down and trailer buttons work up and down
pull the shifter apart and test the swtich
Crosbyman
Blue white UP Green white is DOWN acccording to boat info
bigge31566
checked power all the way back to motor good but cant follow it through motor looks to disappear, power leaving from engine cover tilt, had power from the switch on shifter
Chris1956
That motor likely has a trim limit switch on the tilt rod. See if it is out of adjustment or defective. Trace the blue/white wire from the relay box to the trim limit switch.
