Power Tilt
quackupp
I have a 40hp Force...Power tilt goes down okay, but will not go up. What could be some of the problems?<br /><br />Thanks guys, I swapped out both relays and it works like a charm. This forum is great!!
WillyBWright
Re: Power Tilt
Relay or switch would be my first guesses. Are you hearing any clicking when you trim up? Try swapping the relays. If the problem switches, then it's a relay.
Docdoc
Re: Power Tilt
Might be simpler than a relay. If yours is set up like mine, there is a pull apart connection between the switch and the tilt unit. Check that for corrosion or contact for both wires.
