pgallipoli
- Jul 18, 2010
- 11
I have a 2-part issue for my 1990 Volvo 570A (GM 35) DP-A
1 - Power Trim: Since I bought the boat, power trim was dead. I studied the wiring diagram but can't seem to tell how to run a test 12V to go up and down. Is there a magic wire to hit with +12V on the motor to trigger it if I disconnect all the relays? I'm not sure if it's prestolite or oildyne. I figured if I could bypass the relays, I can run a 12V one direction or the other just to see if the tilt motor works or not. My tilt guage says 62, reverse sputters a bit, red light flashing, so I figure I better get this fixed ASAP instead of running in "beach" mode. Any thoughts how to test the pump directly? if it works with 12V, I can go trace the rest of the wires.
2 - Somewhat related; after spring wake up; running the boat fine for hours; there was a slight squeal/squeak occassionally on light turns (or adjustments). I took a quick look at power steering belt, alternator belt, all else was working fine. A slight correction of steering wheel made the noise go away. Later in the day the squeak got worse and would only go away with a big change in turning, or bump the throttle down a bit. I opened the engine hatch and it was loud like a piston with no oil scratching the block. Funny thing is you could give it a touch more throttle or less and the noise went away. I was searching up and found possible issue with gimbal (does not seem to have a grease fitting like the mercs), PDS bearings (but looks like this drive might not have one), or possible bearing going out in the steering pump or circulating pump. I'm going to remove some belts and see if turning by hand gives me any clues. Running at idle or in neutral was fine, and 90% of the time running under load or every 3/4 throttle was fine; just figure I need to track it down before something goes BOOM when a bearing freezes. Somewhat along these lines, maybe we are actually running the drive trimmed up; but it looks OK from the dock, and hopefully if we can fix #1 here, we'll be able to trim up or down and see what happens. I'll also replace the belts and see what happens.
Any expert thoughts?
I don't think the boat has been out of water for 5+ years; cooling is fine runs great except the new squeally issue; sounds a bit louder than a car with a bad belt; but can go on for a 60 seconds if not throttled down.
Thanks in advance, this place is great!
Reno
Reno
