Power trim down question
hap777
I recently had my boat motor winterized. i asked the mechanic to remove the battery from the boat as i wanted tto keep it warm in the house for the winter. He did that, but now I want to power trim the motor vertical (down), but not sure which cable in the boat is negative or which one is positive. I need to know this as I plan to hook up booster cables from my car to the cables in the boat to power down the motor. (Or is that not a good idea?)
How would you do it?
Thank you
alldodge
One should be red and the other black
Not knowing what you have, the Positive will come from the starter post and Negative will come from the Block
