Re: Power Trim fluid
Either 10-40 motor oil or Auto Trans fluid will work fine.<br /><br />All it has to do is work at hi or lo temps, not leak through or gum up the valves or seals and such, and not eat the gaskets or 'O' rings in the system. And either will do that quite well for several years without needing to be changed.<br /><br /><br />A lot of mechanics data you see is subjective. Many, many things will work fine in the various applications; but the folks putting together a manuel feel the need to appear decisive and authortative. So, they just make a decision to print/use one thing or another even though 20 other fluids will do the same job just fine.<br /><br /><br />Oh,,,<br /><br />Often mechanics will recomend you not do something for a few different reasons:<br /><br />1. They want the item to wear out, so you can pay them to fix it.<br /><br />2. It usually doesn't need to be messed around with much in the first place.<br /><br />3. If you ask such a question, they think you really aren't smart enough to be working on it in the first place, and don't want you calling them to ask 387 questions they have to stop what they are doing to make money, and answer for free while pretending not to be annoyed.
