power trim for 50hp evinrude
C-RAVEN
would like to install power trim for 50hp 2-cylinder<br />evinrude. whats the best way to go ?<br />i have looked at the "cmc pt35 and pt130" units<br />on the web.<br />are they good or is there a better way to go ?<br /><br />thanks
OBJ
Re: power trim for 50hp evinrude
The CMC units are very good units Raven and you get a jack-plate to boot. If you go this route, be sure the steering cable dosen't have to much of a bend in it to get to the motor. The CMC units are also cheaper than OEM TNT units.
C-RAVEN
any idea as to how complex the installation is on the cmc trim units ?<br />can the average monkey wrench do it?<br /><br />thanks
OBJ
Yep....not impling yer' a monkey though.... :) <br /><br />Comes with instructions that are pretty well thought out. Basic needs are drill and 1/2" bit. Wrenchs. No big deal.<br /><br />EDIT: And a way to support the engine while your going through the mounting process.
Jcrain
Got a website for that TNT?
Jcrain
Ok, I got a CMC pt130 unit. Hooked it up to a 90 model 40 horse Johnny on a BassTracker Pontoon boat. The Steering cable won't hook up from it's original hole in the pontoon boat due to the 6 inch setback of the johnson. Any ideas?
Jcrain
Make that " Bass Buggy " pontoon boat in above posting
Jcrain
The cable won't make the bend. The existing hole is pretty close to the end of the boat. Can I just take it out of the existing hole and route it back behind the ledge or does it have to have the support of the hole/ledge
OBJ
Is the steering cable to short or it just won't make the bend? You might have to re-route the cable. Any chance of moving the hole back?
OBJ
Sure ya' can. If you can get a couple places for wire ties, these would keep it from flopping around and your good to go.
Jcrain
Finaly got it. Had to cut a 2" hole in the verticle alum. piece that holds the battery box. The CMC pt 130 works like a dream. Other than the steering cable hassle, it was a peice of cake to install. Might be that the problem was because of putting it on a 'Toon instead of conventional boat.
