Power trim Hoses
malrv1
Hi
MC-1 Power trim with early type pump.
Can anyone tell me which is the up and which is the down port on the bottom of the pump? There are two ports one has a second fitting that goes to the trim sender I think? Also the same for the rams. Mine is all apart and not sure were to connect the hoses.
Thanks
Mal
Ayuh,..... Welcome Aboard,...... The port in the pump that the ssteel braided line screws into is the Up circuit,......
On the transom manifold, the forward port is up, same as on the cylinders,......
The aft ports are the down circuit,.....
malrv1
Great thanks for the reply. I had worked out the pump but was not sure on the rams.
