Rocky Larsen
- May 22, 2014
- 6
Hi There,
I recently got a second hand 1985 outboard Evinrude motor with power trim. When purchased it did not have the relays or wiring completed on the power trim. Now that I have bought all the parts and wiring, I have attempted to do it myself.
I have followed the wiring diagram I found online which can be found at the link attached.
I have connected the positive cables from ports 87 on the relays to my kill switch which is also fused with a 40amp fuse box. I also have the red wire from the trim switch connected to the positive connection of my kill switch.
I have the ground ports and also the black wire on the power trim connected to the negative terminal on my kill switch.
Every time I click UP or Down on my trim switch I blow a fuse. I have tried to hard wire the positive wires by removing the fuse box and the relays start smoking when I click up or down. The trim does move however... Obviously I am getting too much juice somehow and the wiring is wrong.
Could you shed some light as to why or where I have gone wrong?
Cheers,
Rocky
http://www.instructables.com
Cheers,
Rocky
