I have a Mercury 40 ELPTO and the trim is acting up. It will raise up but then slowly drop back when above maybe 1/2 throttle. Works fine when going slow or when motor is off. Already checked power trim fluid and it was good. Any thoughts?
Thanks. It will go up and down and stay there, BUT when under power it will raise up and then drop down. Weird?
Thanks alot. I was just trying to find out why it would work fine until and then drop when under power. I guess this will be a project for the winter.
Thanks. Much appreciated.
don't take the pump off of the manifold and don't mess with the big nylon release valve too much. then it will be really hard to get yourself into trouble. There is no meaningful documentation. Before taking apart set yourself up a clean area with a sketch pad for notes. When you split the piston from the base have the whole thing inside a trash bag. I've had them shoot oil 15-20 feet across the shop if I don't release the pressure first. Even after pressure is released the merc system loves to take a big oily dump on your workbench. GL
