Oshkosh1
Ensign
- Jun 8, 2009
- 968
Here's the story...
I have an 85 Wellcraft with a two rocker switch, panel mounted trim/tilt setup.
So...
I could use the bottom rocker(trim) to lower the unit.
Using the bottom rocker to raise the unit did nothing so I just used the upper rocker(tilt) to raise the unit on demand.
I decided to check all of the connections on the backside to see if there were any bad/loose wiring. I went to lower the unit and it DID lower/raise...but then the internals of the button broke and it caused the unit to lower however the motor continued to run for the time it took me to get back to the battery and disconnect the power...about 10 seconds. Sure enough the little spring loaded "nubs" had came out of the plastic rocker assembly. I reassembled it but now it won't lower...only raise to the limit switch and tilt up with the upper rocker. When I go to lower it the solenoid only clicks.
Now, since the motor was running up to the point the power was cut, I'm guess the motor didn't "burn out" because there was no smoke or horrible sounds. The assembly was a little warm...but not hot, to the touch.
Is there anywhere I can get a new switch, or any ideas on how to fabricate another one?
thanks
So...
thanks
