power trim leak repair
pelletman
My 120 powertrim woeks fine both up and down but allows the engine to fall over about a 5 minute
period. The fluid level is fine, so I am assuming that my cylinder seals are leaking on the port side
cylinder. Is there a standard seal kit to buy, and is this a difficult job to tackle ?
foodfisher
Re: power trim leak repair
Fluid level is fine, so I'm assuming there is no external leakage. If so, the pump is leaking internally and needs rebuilt.
jerryjerry05
Pellet, we need a year and model??
Profile,location?
The port trim cylinder??
The port is a shock and has no hyd fluid.
Like Food says the pump is probably the culprit.
But you need to do the leak down tests.
You have a manual?
http://rapidshare.com/files/453372553/Force_Outboards_1984-99.pdf
Here's the link to an online manual.
Kinda sketchy but if you try hard you can follow it.
You'll need a couple of fittings.
