quantumman29
- Jul 15, 2004
- 105
i removed the motor for the power trim,the brushes looked fine,the motor looked fine,no loose or broken parts visible,i put it back on,tightened it up,added oil to the reserve...<br /><br />the motor works fine after i give it a whack with a hammer,its been workin fine now in the driveway,previously it just stopped workin altogether,then if i hit the motor with a blunt object,it would work,then it would struggle,then it would stop workin altogether until i hit it again, now it seems to be workin fine again...<br /><br />QUESTION? i just replaced the cranking battery in the boat,it is a smaller battery with alot less cranking amps, could this possibly have anything to do with the power trim motor not working properly? maybe its not getting enough power to operate it fully? why would the motor work after being struck with an object?<br /><br /> thanx,<br /> mike
