power trim pump on 1999 Merc 125 outboard hesitating. why?
mallardtone-man
hey guys I recently bought this outboard and normally it trims up and down fine however I have noticed a few times when I had it trimmed part way up already it would refuse to go the rest of the way in that direction, it would go down and once I trimmed it all the way down it resume normal function and seemed to go up and down fine. also once or twice when hitting the button On the motor itself I could hear what sounded like the pump running but got no movement out of the motor I released the switch and click it again and it worked. just wondering if these are warning signs of a failing trim pump or switch thanks in advance for any help James
schematic
check the fluid level. If its fine, its likely a cracked cylinder
Change the fluid, it sounds like contamination
mallardtone-man
ok I would like to change the fluid either way but I will start by checking the level can anyone tell me how to do either of these things?
If you Google changing Mercury tilt and trim oil and about 1000 links to procedures and videos on YouTube show up
