power trim relay for 1991-120hp
hey guys:back again-btw i replaced my t-stat(130f)and impeller(ist-time to do it).works great,but last time out up trim stopped working down trim ok.switched relays-up ok,down not.sooo i go to advance auto and they dont carry bosch relays and give me a "sorenson"(made in china)computer match-up model and it doesnt work.the little picture drawing on the side of the relays looks the same.the original bosch part# is 0-332-204-150,12v-20/30a.on the side that says made in germany htere is this-067-p2 stamped on it.i did try another one they gave me-same results.i thought that most of these type of relays were the same?should i stick with trying to find the bosch replacement only?any other ideas??? model-1201x91c,ser#22802 thanks again guys im learning alot gary
rickdb1boat
Re: power trim relay for 1991-120hp
I'd Ohm out the new one they gave you and compare the results against the old one that is good. If they are different readings, either the one they gave you is defective or you need the correct relay from a different source.
roscoe
You can get one from a Merc dealer for about $12
