power trim relays
socalboataddict
thanks to this board I was able to diagnose my power tilt problem. It was a bad up the uptilt relay. <br /><br />second, Im trying to buy two replacements but are having a hard time locating one and/or a part number.<br /><br />I have a 1993/94 90HP mercury outboard with the serial # od205997. <br /><br />I can buy it through iboats or anywhere that have the parts with decent price. <br /><br />thanks for your response.<br /><br />Regards<br />JC
socalboataddict
Re: power trim relays
" It was a bad trim/tilt relay." oops......typo correction added.<br /><br />thanks
Chris1956
SoCal, Those parts should be readily available. I also found that Merc's price was the same as West Marine, at least for my Starter Solenoid. You can shop around, but it is likely you will not save too much $.
