Power tune engine cleaner
portd
Mercury 2002 115hp efi fourstroke
Going through repair manual 100 hr service came across step 14
12. Check control cable adjustments.
13. Inspect timing belt.
14. Remove engine deposits with Power Tune Engine Cleaner
My motor has 300 hrs on it have not done this step any thoughts on this product or is there another i should use
Thanks
portd
Re: Power tune engine cleaner
did some more online research i dont think the product is for my engine more for carburated efi , found post on another message board about using Mercury quick kleen in the fuel
Dave1027
I don't think that Powertune is intended for your engine since you have a four stroke. Your's is like an auto engine. You should change the oil.
Sea Rider
Don't know about 4 strokes engines, this product works perfect on 2 strokes engines, a must use each 100 metered hours or longer, to keep carbon building inside engine interior cleaner and running smoother.
Happy Boating
merc850
It says on the can "for 2 and 4 stroke engines", I have used it in my car as well as my outboards.
Faztbullet
Better than sliced bread!!!! Work great in all engines....
portd
thanks for the replys how would i get the aresol spray into the engine ,
Dave1027
Sure it does so they can sell more cans. The benefits are nill for a 4 stroke engine. The two strokes build up burned oil. This is why they can use powertune.
jerryjerry05
All motors can build up carbon deposits.Ever take an EGR valve apart?Carbon is why they go bad.
Seafoam can be added in the fuel.J
Dave1027
Actually, water will clean an engine better than powertune because it does not burn but instead turns to steam and steam cleans the pistons and exhaust valves.
