Hello,<br /><br />I increased the power of my engine by several measures dramatically, so the power is now around 40hp.<br />I reduced intake throttlening for better cylinder filling, increased compression ratio, and took care for a richer mixture.<br /><br />Now in a further step I want to enlarge the width of the exhaust ports, so scavenging may be initiated earlier and more air is hopefully pressed into the combustion chamber.<br /><br />Has somebody of you experience with that from a comparable engine ?<br /><br />Has somebody tried to change angles or length of the exhaust diffusor tube ?<br /><br />Greeting from Germany<br /><br />Nordy
