Sea Rider
- Sep 20, 2008
- 12,345
Recently found an old 1/2 filled can of Mercury Power Tuner, was doing the factory recommended 300 hours routine maintenance on a Tohatsu 18 HP, so after work completion, started the engine and squirted 1/8 can through the carb untill engine stalled out, let stand for 1 hour turning flywheel each 1/2 hour for the foam to be evenly distributed through engine interior. Started the engine and went for a 5 minute full throttle operation, the engine sounds evenly, great music and with slight more power than before. Was wondering how many of you guys use similar products periodically and what was the result of it's use compared to not using it at all. This product is intended for boaters that do not add carbon cleaners into gas tanks periodically.
Happy Boating
Happy Boating
