Power valve issue maybe?
Adam_c
So I posted awhile ago thought I had fixed my stalling boat by finding plastic in my gas tank pick up tube. Removed it seemed to run better but still not 100%
Had the boat out today was doing about 30 ish mph for about 20 mins and when throttling down boat sputters and stalls. Was doing some reading about a stuck open power valve that could be the issue.
Would that make more sense then a fuel pump or anti siphon valve?
Those are my next replace if persists ..
Picking up another Carb tomorrow will try that first.
I have 2.5l rochester 2 jet carb
Thanks!
Adam_c
Replaced the anti siphon valve and noticed the old one was quite a bit harder to blow through than the new one. Picked up the replacement carb but haven't put it on yet.
Should I try the boat first with the new anti siphon and see if the problem persist or also put the replacement carb on and try then both together?
Lou C
Might want to try one thing at a time that way you know what affected your results.
Kenny, burred in the OP's thread is 2.5 liter, so a 120hp
never understood people spending money on a complete carb when a $30 kit is usually all that is needed.
Adam_c
The problem with the rebuild is I need it working by Saturday.
Changed carb not the issue ran boat from external gas tank same issue and also with a hand pump.
Disconnected riser runs great... Flapper looks fine it's a rubber one wondering if I have crud stuck at the bottom.
Does the very bottom exhaust disconnect from the outdrive/ engine somehow to clean it?
the exhaust tube is bolted to the transom shield. you can remove your motor to remove the exhaust tube
as for a carb rebuild, its a 1-2 hour job
Adam_c
Scott Danforth Thanks, my issues was more ordering one on time. But none the less now I have 2 "no biggie.
Ya moving the motor seemed like a heavy job I put a shop vac down the exhaust and ran a hose through it put it all back together ran great for about 30 mins then problem persist. Sputters and stalls I'll upload a video to YouTube so people can see. Any other idea why when warm it does this? Running out of things to change.
Go back to the basics. Read the plugs, check the choke aettings
kenny nunez
Put a volt meter on the + side of the coil to check that the ballast resistor circuit is not breaking down. You should see around 8 volts, run it with the volt meter on to monitor the voltage when it starts to cut off.
