Re: Power winch
Useage takes its wear on an electric motor the same as a gasoline one. Although they require less maintenance, things still do wear out.<br /><br />If you can crack the case of the winch unit (and feel comfortable that you can put it back together correctly!), check out the brushes on the motor. Over time, these will wear down and start arcing, causing overheating and reducing the power delivered. You may need to regrind the brushes, or look for replacements. These are designed as "disposable" parts, because the premise of the electric motor has this part contantly wearing on the commutator. Replacement brushes shouldn't be impossible to find.<br /><br />It is also possible that the contact between the brushes and commutator have some sort of gunk/buildup in there, especially if this old unit has been left exposed to the elements for many years. If you can clean out the buildup with a soft lint free cloth, and then use an electric contact cleaner, you may realize greater performance.<br /><br />--Dan
