Powerhead change
merc1
Hi all. Hears what i have both are merc's one is a 80HP#s2290006 71-72 i think The other is a 85HP#s 4295564 75-76. The bolt holes dont line up i thought they were the same. I want to use the power head of the 85HP on the 80HP Is there something i am not doing right or will it not work. When i bought it the man said it would work. Any help i would be greatfull.
Laddies
Banned
Re: Powerhead change
Those 2 engines use a differant exhaust plate (as you know now) the only way to make that exchange is to by also exchanging the torque tube (mid section)
merc1
Thank You. Now if i get a mid setion will my lower unit work and will there be anything that i will have to do.Thanks merc1
Laddies
Banned
The simplist thing to do would be to get the whole mid section off the powerhead you want to use (torque tube, mount clamps exhuast plate and etc.) and slide your lower unit into and your good to go
merc1
Thank you. This is what i needed to know. God Bless merc1
merc1
Hi all. Can anyone tell me what other mid section will work such as a 90 hp to 115HP. As in the other post this is a 85HP Merc and cant seem to find one without paying an arm and a leg.I can find the 115 easy and a few in between but not the 85 hp. Any help i would be greatfull. Thanks.
Chris1956
Merc1, I had always thought the 85-115 inline midsections were the same. I made that assumption because I kow the lower units will interchange. Perhaps you cam match up the part numbers on the exhaust extension between the 850 and the 1150. If they are the same, the powerheads should bolt up.
merc1
Yea i never thought of that. They should be the same. Thanks and God Bless,
