Re: powerhead rebuild standard procedure?
There really isnt much advice other than ,if,you are going to rebuild the almost 20 yr old motor again.Be sure the rest of the engine ,including the Trim and tilt,the lower unit including the alum.casing that hoising it is going to work for a couple seasons for ya.Be sure .the NEW rebuilder will bore each cyl to the next oversie which you say is 30 over.All bearings will be replaced,because for that price,which is right should include new bearings,gaskets,water deflectors that 1st guy left out,carbs rebuilt,filters changed,there should be NEW piston kits installed,not some used 30 over pistons that were laying around the shop with replacement rings.I worked for a few rebuilders.There are the guys that do it right,and those that dont.Be watchful of the 50/50 warranty guy.That means,if it blow ,you pay 50%.50% at retail can cost as much as the orig.job.Oh,and NEW parts should be ,NEW PARTS.Not used parts ,NEW to the eng.Meaning used.Your block,heads,crank and connecting rods will be reused.if their bad,it can cost you $$.Im sorry to say I've alot in the business.Most boaters dont know the mecanics.Then add to that %%%.What % of people use their boat alot.Take in consideration.Weekends only,you then have weather,illness,parties,vacation etc.So a warranty is good for how long?if you live where I live in South Fl.you may boat more than my friends in New England.If your a commercial guy.Some of the fly by nighters wont honor them ,it will be in the fine print.You likely got hosed by the first guy.He played the % game and won.You didn't bring it back.He made $$ and only fixed one cyl.Ive seen it.There are the guys that will fix the one cyl.BUT not charge you for a complete rebuild.Maybe 5-600.I am curious as to the state you live in,I know there are a few rebuilders,or should I say hosers in Fl.But I also know there are some great rebuilders.A wise shopper is a happy shopper.Good luck.
