I have a problem with my 1986 150 hp overheating. 2 years ago it only ran hot at low rpms and cooled at high rpms. Replaced the stats(which I found it did not have), poppet valve, and waterpump last May. Last summer it would start to pee for about 5 min. and then stop peeing and steam starts to come out. I always stop the motor when this happens. I have been through everything several times and everything seems to be ok, but the problem is still there. The psi shows 3 to 8 at slow to fast speed. Could the powerheads get clogged and cause this problem? Does anyone have an idea?
