Powerjet problems help needed
VISH136
Hi guys,
Was wondering if anyone worked on a volvo penta pjx power jet before. i have a 1998 larson flyer with a 4.3l and pjx jet drive, the bearing broke where the flywheel attaches to the shaft on the jet drive in the stern. I have removed the circlip that holds the shaft and took the back of the jet off removed the impeller from the also i got the shaft out from the housing. the bearings came out in pices i wanted to know how to assemble back the shaft and bearing also there is a housing insinde the housing on the stern where the shaft goes through that has all the seals in do i have to remove that and how? the bearings did break up i don't know if there is like a track inside that i have to pull out ANY HELP WILL BE HIGHLY APPRECIATED
Thanks in advance.
