I do not understand terminal #1 on the powerpack.<br />With a needle volt meter I get 0 volts from the disconnected Black/Yellow to ground with the key on or off. When using a digital meter I get 1.45 volts with the key on and 0 volts with the key off.<br /><br />Is this a problem? Does the switch need to be replaced?<br /><br />What is the purpose of Terminal #1. I know it goes to the key switch. Is terminal #1 sending power to the key switch once the motor is running? Why?<br /><br />Thank you,
