Powerstop Brake kits.
MTboatguy
Re: Powerstop Brake kits.
I don't think the parking brake adjusts the rear discs, at least I know it does not on my Jeep...and it didn't on my Ford Pickup when I had it..
Boomyal
I don't have any experience with the Powerstop but how many miles are you getting in 12 to 18 months?
Heavy hauling?
Sounds like you might have a couple of hung up calipers.
I got about 60,000 miles on my 3/4 Suburban (about half as a light tow vehicle) on the brake/rotors. I also use GOOD brake pads...dust free.
I've cut/turned the rotors twice (total over 90,000miles) and the next brake job I'll replace them.
What year is your suburban? I have a '94 2500 with a 454 boat anchor in it. To date it only has 44k miles on it. At 17.5K miles, the front pads were shot. They were replaced by OEM GM pads. Again, a 35K miles, the pads were shot. I replaced them with NAPA's best. I am not sure about the status of those pads as the beast sits unused due to insurance and fuel cost.
All of this mileage was light to moderate use. I pulled a mid weight boat trailer for a relatively few of the miles. I doubt the calipers are sticking.
jeffnick
My van has over 100,000 miles on it and I'm still on the original brake pads; about 50,000 of those miles were pulling a trailer. The way you drive has everything to do with how long your brakes last, but even so, some systems are not up to par. My Crown Vic needed brakes about every 40,000 miles and I was just as easy on it. I concluded that turning rotors is never a cost effective venture (even tho' I can do it myself).
If you're 'eating' brakes, it's not a bad idea to get away from the stock set-up.
bruceb58
Not sure about your year but I had the same truck but a 99 version and there was a TSB because they needed to change the proportioning valve because too much pressure was given to the front brakes. You are lucky that you get 17.5K out of them. I got around 9K. The new body style in 2001 and up did not have the same problems.
D
DJ
Guest
Use your parking brake, that adjusts the rears, as mentioned.
Are you serious??
I have rear discs. Thats new to me.
No, My mistake. I was thinking of something else. Sorry.
I strongly recommend remaining OEM. Only OEM meets FMVSS standards. NO aftermarket brand does. Just ask and make them show you the credentials. They can't.
The Motorcraft "Super Duty" pads meet FMVSS and will give much greater life for heavy brake loads.
Fuel, steering and brakes are three areas I do NOT mess with. There was a lot of thought that went into the original engineering. I don't proclaim to be smarter than a dedicated team and thousands of hours of testing.
dockwrecker
Well you'd be wrong here. ISO/ts16949 standards are worldwide, including our beloved FMVSS. This standard is widely used for OE and aftermarket parts grading. We didn't make it up. It certifies compliance for the manufacture of OE and aftermarket parts, practices and standards for the industry. Powerstop is ISO/ts16949 compliant or better.
There are many components manufactured locally such as brake lines that have specific crimpings/markings to identify their origin that are registered with the DOT. Your local hose shop that does any OTR work and manufactures replacement hoses has a DOT cert and identifiable crimp as an approved replacement supplier. Such is with brake pad manufacturers and other automotive parts suppliers. But the OVERRIDING standard is TS16949 for parts compliance. This is what the aftermarket (and who most often times are also the OE) build to.
DJ I do share your regard to the initial engineering in OE applications, I'm merely pointing out that the engineering of the OE part is not unique to a FMVSS spec, but rather ISO standards that are common to the industry. I agree that a manufacturer's expected load on something like a brake or suspension component is certainly driven by the sum knowledge of the vehicle design, thus not universal. However peer review of such a component leads to advancement in design and shouldn't be dismissed as inferior, especially when design elements meet or exceed the original ISO specs. It's a better mousetrap so to speak. The same thing that happens every day in any OE manufacturer's R+D department for the next model year. Development is good, and the next great aftermarket product may be the OE part of the future. Detroit, Japan and Germany don't think this stuff on their own and God knows the Chinese and Koreans haven't had an original thought in years. Aftermarket ain't all bad when held to standards.
Tim Wagner
I ordered the brake/rotor kits on the 29th and they were on my porch friday morning. (holy cow thats fast. They offered free shipping too)
So, since friday they have been installed.
All is well and working normal so far. Ill be reposting on this calamity in about 6 months.
Fingers are crossed!!
