Re: Powerwinch parts
Bob,I doubt you will find any "real" parts except for harness's,cranks,cable etc.(West Marine)<br /> Being un-able to locate an internal bolt inside(broken tensioner bolt/knob),I replaced my broken 912c Powerwinch last fall with a 30,000lb MVP winch.They are available on E-bay/Northern Tools and are good quality($200+-).It fits the 3 pin(trailer) plate perfectly and comes with remote.I made sure the cable diameter was the same or heavier.You have to install thier circuit breaker and harness.I tapped into my Powerwinch harness because the new one was a little short for a Full-size pickup w/8' bed.If you go for the new winch check E-bay first(where I got mine)for a better deal.Do not purchase a 6,000 lb winch as the wire guage is too small(unsafe).They have a 30,000 and 40,000# winch.Although this sounds overkill,I would NOT buy smaller for safety reasons/wire diameter.Winches are rated at "rolling capacity".<br />I feel I made the right choice.
