CableGuy1978
- Jul 13, 2010
- 66
Hello folks,
I know I have seen threads on here regarding this issue, but damned if I can find them, or ones with enough info.
Last year I changed out my coupler. I checked the alignment before and after I pulled the motor out, and everything lined up perfectly. I had to completely re-align the motor after the coupler as somewhere along the way the setting on the mount went way out. Still no issues then.
This year I changed the gimbal bearing along with bellows and such. I decided to get all of the proper purpose made tools for pulling and re-installing the bearing. That part went abnormally smooth
The bearing went in and bottomed out exactly as described in the threads here. However, I cannot get the alignment correct now. Originally I had never changed the setting on the front engine mount and it seemed way off. So, I changed the front mount, all the way down and gradually raised it. The bar seemed to go in a bit easier, but it I put too much on it it would get stuck. Since the bar should slide in with little force when aligned properly I don't see the sense in forcing it in if the alignment it off, besides, the bar gets stuck easily enough and this is frustrating.
I have tried tapping the bar while it is in the bearing as described in some other posts but it doesn't make any difference.
Other than the front mount, the only other variable here is the bearing. Any ideas on lining this thing up would be great. Even some direction to posts that I may have missed.
Thanks...
Thanks...
