FreeBeeTony
- May 15, 2002
- 3,995
Installed a new "upper" shift cabe this spring, lower was replaced 2 years ago and moves smoothly.<br /><br />I installed the O/D this w/e and was cheking the alignment of the shift linkage......seems I can get it adjusted in either fwd or rev but not both.<br />I can get it (fwd or rev) adjusted prop locked when in gear in fwd, then when I shift into rev it seems to be locked, but if I push on it too hard it seems to slip. Seems like the clutch dog is not fully engaging in both directions. I can get it to happen in either direction. Seems like this is a very "touchy" adjustment.<br /><br />Seems like there isn't enough "throw" in both direction. I used these instructions an an aid.<br /><br />Are there similar instructions for the upper cable? I adjusted the barrel on the upper cable so I have the same movement in either direction.<br /><br />Any help here would be appeciated. At the end of last season I couldn't get it adjusted in both gears and I thought it was maybe the upper cable......thats why I replaced it. Now I'm not so sure.<br /><br />I just read another post .........anyone ever hear of this?<br /><br />I know my drive is older, but the symptoms sound awfully familiar!<br /><br />Sorry for the long post!
