Tyler,
How do you know it's the wrong way?
The 'correct' direction for forward is that it LOCKS in reverse, and for reverse, it LOCKS when you turn the prop in the forward direction....
You may be confusing forward and reverse, in which case, you put the drive in REVERSE, then lined up the intermediate shift shaft to be facing forward....
We have 3 shift shafts on these drives. (BTW, no such thing as a 'pre-alpha' drive. You probably have a Mercruiser-1 drive, or MC1 for short.)... The shaft that goes through the exhaust cavity in the bell housing is the upper shift shaft. The shaft that is inside the lower housing (with the spline on the top), is the lower shift shaft, and the one that flops around in the upper housing, with the splines in the bottom and the 'shoe' on the top, is the intermediate shift shaft....
You need to split the housings again and change the position of the intermediate shift shaft, just like fishrdan suggests....
HTH,
Chris........
What, just the one?
