thefishinguy
- Oct 9, 2008
- 17
I have a 1973 pre alpha drive that needs a lower unit. i also have an alpha drive that has a bad upper gear case. the question i have is everything is the same on both lower units BUT... the pre alpha has a spring pin on top of the vertical drive shaft and the alpha does not. will this work or not? or how do i make it work
