Thanks for this great forum. I have spent many hours reading and learning. I have a mercruiser 165 out drive that I have been trying to bleed the air out of the trim system. The trim motor runs fine both up and down. Down works fine. Up does not move and the trim pump spins faster Making me think I have air somewhere. I have filled the reservoir and the air bleed screw is out. I have ensured that the trim hoses are attached to the correct fittings. I am able to push the trim cylinders in and out with hoses removed. I get fluid out of hoses when down button pushed, but no fluid out when up is pushed. I have the Selig mercruiser manual. Any fix to this or tricks. Thanks very much. I have tried the bleeding procedure a couple times. This is the two hose trim type. Sorry seloc manual.
