Pre Alpha Trim Cylinders
gshldon
Hello All,
here is the issue I am having:
-out drive would not stay up when trimmed, the hydraulics wouldnt hold it up
-replaced the trim pump, that helped some. it still leaks down, but very slow, it will drop about 3 inches at first, with in a couple minutes, then leak the the rest of the way down over a couple weeks
-I have bled the system, (ran tilt up and down several times
-there appears to be a very lite amount of fluid on the ram it self, nothing leaking out that I can see
-is it possible just a rebuild kit will take care of the bleed down?
-also, should the up and down speed be the same?
-it trims up really fast, but trimming down will take 4 times longer
-not sure if that is normal or if something is connected wrong.
any help is much appreciated
-it is the pre alph drive that I am working with.
alldodge
Re: Pre Alpha Trim Cylinders
I would recommend replacing or rebuilding your cylinders. The link below has everthing you should need and the link on the page takes you to the prices for all are part of.
Trim Cylinder Parts
Hello All,
Ayuh,.... That would be an MC-1,....
I agree with Alldodge, yer rams are draggin',...
That's why it goes down so slowly,...
Ya have greased the pivot pins, Right,..??
gshldon
Thanks for the informatiom.
-Yes Bond-o, I have greased all the fittings on the outdrive, I do that with my regular maintenance.
-The link that was posted for the parts, doesnt match the cylinders I have and the instructions dont match up either.
-the Cylinders I have, have 2 hoses connecting at the end of the cylinder body up against the transom.
-would you happen to have the rebuild instructions for those cylinders? I have looked and unable to locate them.
Thanks so much for all your help.
-Again, is the up and down speeds suppose to be the same? or very close to the same?
