Preferred tilt trim fluid
crazy charlie
I noticed that the Yamaha trim fluid looks like light amber color oil.I have ALWAYS used Dextron ll tran fluid.Does it matter?? I have only owned Evinrudes prior to this 200 hp Saltwater series Yam
dingbat
Fluids.
The fluid in your PT&T system is under extreme pressure that can cause molecular shear, which tears apart the fluid’s molecules, resulting in a drastic loss of lubricity. Don’t use substitute oils like motor oil or power steering fluid. Yamaha Performance Power Trim & Tilt Fluid is specially formulated to tolerate a specific amount of water ingestion and still maintain proper operation, all while withstanding extreme pressures. It also contains special anti-foaming agents the others don’t, to maintain critical lubricity.
You can use Dextron II or III but mix with the existing fluid...
99yam40
The owners manual will tell you what you can use,
I believe my C40 said dextron also
