Re: Pressure checking exhaust mans... how'd U Do It?
A. Home Depot for a 3/4" MPT to garden hose adaptor. Screw into 3/4" FPT hole in manifold.<br /><br />B. A sheet of rubber big enough to cover the manifold to riser flange (an old tire tube will work).<br /><br />C. Put rubber over manifold flange, mark then cut out bolt holes (or around studs).<br /><br />D. Bolt the riser back to the manifold with the rubber gasket in place.<br /><br />E. Hook it up to the garden hose and wait a few minutes to see if any water appears in the exhaust tubes of the manifold.<br /><br />F. If the manifolds are raw water cooled with salt water, replace them anyway. If raw water cooled with fresh water and older than 8-10 years, replace them anyway. If coolant cooled and older than 12-14 years, replace them anyway.
